[Qgis-user] Re: [Qgis-developer] rendering GRASS rasters broken
in UTF-8 locale
Otto Dassau
otto.dassau at gmx.de
Fri May 9 05:27:19 EDT 2008
I work on QGIS 0.10.0 + SVN Revision 8416 (today) on Debian testing i586, QT
4.4.0 rc1 in DE.utf8 locale and have the same problem testing with spearfish
aspect map (and other).
Regards,
Otto
On Fri, 9 May 2008 16:16:05 +0800
"maning sambale" <emmanuel.sambale at gmail.com> wrote:
> I'm just doing the same in windows (QGIS Io)
> GRASS DEM with colortables from r.colors color=etopo2
> I get no problems so far
> cheers,
> maning
> On Fri, May 9, 2008 at 3:17 PM, Maciej Sieczka <tutey at o2.pl> wrote:
> > Maciej Sieczka pisze:
> >> I'm currently using QGIS 0.10.0 + SVN r8401 on Debian tetsing x86, QT
> >> 4.4.0 rc1 in pl_PL.utf8 locale.
> >> Any GRASS raster (even as small as 50x50 cells) which has a colortable,
> >> freezes QGIS. QGIS last debug words, before pressing OK in the "Add GRASS
> >> raster" dialog, are attached in a txt file.
> >> Also, when I load a GRASS raster *without* a colortable it renders OK
> >> (ie. all-grey, as one would expect since it has no coloratable assigned),
> >> but when I try reducing the window size QGIS crashes, saying:
> >> Warning 1: GRASS fatal error: region for current mapset is invalid line
> >> 16: <e-w resol3: 29.98442368> run "g.region"
> >> When I start QGIS in C locale (eg. from a terminal after "export
> >> LC_ALL=C") neither of these problems take place - GRASS rasters with
> >> colortable are rendered OK and I can stretch/reduce the window as I like
> >> without a crash. What's wrong?
> > Folks,
> > Does anybody else have this problem too? Maybe it is just me.
> > Maciek
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
