[Qgis-developer] [VOTE] Remove Qt4.2 minimum in favour of Qt4.3
Martin Dobias
wonder.sk at gmail.com
Mon May 12 11:10:21 EDT 2008
On Mon, May 12, 2008 at 2:41 PM, Tim Sutton <tim at linfiniti.com> wrote:
> Hi Folks
> I would like to change the minimum requirement from Qt4.2 to 4.3.
> Version 4.2 is old now and I am busy revamping all the dialogs as part
> of my ui revision for 1.0. release - and I would like to use Qt4.3 for
> this (and make use of some of the new features it has). Could you
> please cast your vote if you are in favour?
+1
I remember there was a svg rendering patch for composer flying around
which needed Qt4.3 to work... it should be applied to SVN too.
Martin
