[Qgis-developer] [VOTE] Remove Qt4.2 minimum in favour of Qt4.3
Steven Bell
botsnlinux at gmail.com
Mon May 12 12:05:23 EDT 2008
> Martin Dobias <wonder.sk at gmail.com> wrote:
> On Mon, May 12, 2008 at 2:41 PM, Tim Sutton <tim at linfiniti.com> wrote:
> > Hi Folks
> > I would like to change the minimum requirement from Qt4.2 to 4.3.
> > Version 4.2 is old now and I am busy revamping all the dialogs as part
> > of my ui revision for 1.0. release - and I would like to use Qt4.3 for
> > this (and make use of some of the new features it has). Could you
> > please cast your vote if you are in favour?
> +1
> I remember there was a svg rendering patch for composer flying around
> which needed Qt4.3 to work... it should be applied to SVN too.
> Martin
+1 for me too. The SVG patch has already been applied (with compiler
switches to not break Qt 4.2).
Steven
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080512/176faf93/attachment.html
