[Qgis-developer] Re: Failing unit tests with recent commits
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Sat May 17 11:18:10 EDT 2008
Hi Tim,
Yes, good idea to make an automatic project file transformation
The change in the test was still necessary because it is nearly impossible to
find a conversion factor that makes every pixel look the same.
Regards,
Marco
Am Samstag 17 Mai 2008 16:06:16 schrieb Tim Sutton:
> Hi Marco
> I wonder if its not better to make the change in Magnus Homanns rev-up
> code since this issue is going to affect everyone with old project and
> QGS files.
> regards Tim
> On 5/17/08, Marco Hugentobler <marco.hugentobler at karto.baug.ethz.ch> wrote:
> > Hi Tim,
> > The failing renderer tests are caused by the fact that units are now mm
> > instead of pixel.
> > I' going to change the width/size values of the test qmls and the test
> > images
> > to make it run again.
> > Regards,
> > Marco
> > Am Freitag 16 Mai 2008 21:19:56 schrieb Tim Sutton:
> >> Hi All
> >> Recent commits in the last few days have introduced regressions (as
> >> can be seen by running the unit tests). Please remember to run the
> >> unit tests before committing changes to SVN. Currently we only have a
> >> few tests but they test core stuff like rendering. If you committed
> >> anything in the last few days please take a look and see if you have
> >> introduced these issues.
> >> The issues involve mainly symbol sizes for rendering as best I can
> >> make out. BTW I have not yet tried the test suite under win,but it
> >> works under mac & lin.
> >> Many thanks
> >> Tim
> > Dr. Marco Hugentobler
> > Institute of Cartography
> > ETH Zurich
> > Technical Advisor QGIS Project Steering Committee
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
ETH Zurich
