R: [Qgis-developer] qgis-grass crash
Marco Pasetti marco.pasetti at alice.it
Mon May 19 13:41:24 EDT 2008
What about the PROJ.4 libs? WinQGIS uses 4.6.0 [1]
[1]
http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html#PROJ.4
Marco
-----Messaggio originale-----
Da: qgis-developer-bounces at lists.osgeo.org
[mailto:qgis-developer-bounces at lists.osgeo.org] Per conto di Paolo Cavallini
Inviato: lunedì 19 maggio 2008 19.18
A: cavallini at faunalia.it
Cc: DebianGIS; qgis-developer
Oggetto: Re: [Qgis-developer] qgis-grass crash
Paolo Cavallini ha scritto:
> Hi all.
> I'm researching on this nasty bug, crashing qgis when opening a grass
> vector. I recompiled most of the toolchain from deb-src (from
> lenny+debian.gfoss.it), and I still get:
Some further info:
the crash happens with a custom projection (modified gauss-boaga, thanks
Markus):
QGIS SRSID: 100000
PostGIS SRID: 0
+proj=tmerc +lat_0=0 +lon_0=9 +k=0.999600 +x_0=1500000 +y_0=0 ellps=intl
++units=m +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
qgis does not appear to recognize it, try to use the default projection
(wgs84 in most cases, the same gauss-boaga): if it finds wgs84 it opens the
vector (with a wrong projection), if it finds G-B modified it crashes.
Anyone has a clear view on what's happening? Remember, the same data &
projections do not cause qgis to crash on win.
Many thanks.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
