[Qgis-developer] Mac Use of QFileDialog
Tom Elwertowski telwertowski at comcast.net
Fri May 23 00:58:30 EDT 2008
John C. Tull wrote:
> I also get frequent crashes in the file dialog when using project files
> with many layers (say, 40+). Maybe a native dialog will cure this.
Once the file dialog passes a filename to qgis, its work is done. If you were doing a multiple selection of 40+ files directly in the open dialog, I might be suspicious of the dialog. In this case, I'd be interested in looking at a crash log to determine where the problem is occurring.
Tom
