[Qgis-developer] QGIS Python support in a library
Tim Sutton
tim at linfiniti.com
Wed May 28 11:54:48 EDT 2008
Hi Martin
Thanks for doing this change - I think it will be a nice improvement.
For me I get this error when trying to build on OSX:
[ 72%] Built target python
Linking CXX executable qgis_help.app/Contents/MacOS/qgis_help
[ 74%] Built target qgis_help
Linking CXX shared library libqgispython.dylib
ld: Undefined symbols:
__ZN14QgsApplication11pkgDataPathEv
__ZN14QgsApplication19qgisSettingsDirPathEv
__ZN16QgsMessageOutput19createMessageOutputEv
__ZN9QgsLogger5debugERK7QStringiPKcS4_i
/usr/libexec/gcc/i686-apple-darwin8/4.0.1/libtool: internal link edit
command failed
/usr/libexec/gcc/powerpc-apple-darwin8/4.0.1/libtool: internal link
edit command failed
lipo: can't figure out the architecture type of: /var/tmp//cc9EZSsS.out
make[2]: *** [src/python/libqgispython.0.11.dylib] Error 1
make[1]: *** [src/python/CMakeFiles/qgispython.dir/all] Error 2
make: *** [all] Error 2
Regards
Tim
2008/5/28 Martin Dobias <wonder.sk at gmail.com>:
> Hi all,
> as you probably know, until now embedding of Python to QGIS was done
> directly in the QGIS application sources and the support was
> implemented using conditional #ifdefs. So when building qgis binary,
> you got it with or without python. This wasn't a very good solution
> and was doing problems for packagers since there was no easy way to do
> optional installation of python support.
> In my recent commit to trunk (r8530) I've done the embedding in more
> flexible way. All python support code has been moved to src/python
> directory and now compiles as "qgispython" library. When QGIS
> application is started, it checks for the presence of this library and
> tries to load it and init python support. If something is wrong, the
> python support (i.e. python plugins and console) is disabled.
> I've tested this new approach on my ubuntu box with success, but other
> platforms are untested (I could try it on win, but I don't have access
> to OS X). So Mac and Win wizards please give it a try to see whether
> it's working fine there or not. I know that Mac makes difference
> between shared objects and libraries (MODULE / SHARED option in CMake)
> but I have no idea which one to choose there so try changing this
> first if you encounter some problems.
> Generally I hope it won't produce any great havoc, but one never knows
> :-) If that works fine, you shouldn't notice any change. If that
> doesn't work fine, nothing python-related will work. Additionally,
> this change has no impact on python bindings or plugins.
> Regards,
> Martin
> Qgis-developer mailing list
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
