[Qgis-developer] Mac build error
John C. Tull john.tull at wildnevada.org
Wed May 28 17:47:16 EDT 2008
Tim,
I noticed I am getting errors on the wfs plugin on OS X. I did not
notice this earlier today, but was not observing the make output
either. Were you coding on this today?
John
Scanning dependencies of target wfsplugin
[ 59%] Building CXX object src/plugins/gps_importer/CMakeFiles/
gpsimporterplugin.dir/moc_qgsgpsplugingui.o
[ 59%] Building CXX object src/plugins/wfs/CMakeFiles/wfsplugin.dir/
qgswfsplugin.o
/Users/jctull/sources/qgis/trunk/src/app/../python/qgspythonutils.h:
36: error: invalid function declaration
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: In constructor
‘QgisApp::QgisApp(QSplashScreen*, QWidget*, Qt::WFlags)’:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:376: error:
invalid use of undefined type ‘struct QgsPythonUtils’
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.h:53: error: forward
declaration of ‘struct QgsPythonUtils’
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:388: error:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: In destructor
‘virtual QgisApp::~QgisApp()’:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:471: warning:
possible problem detected in invocation of delete operator:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.h:53: warning:
forward declaration of ‘struct QgsPythonUtils’
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:471: note:
neither the destructor nor the class-specific operator delete will be
called, even if they are declared when the class is defined.
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: In member
function ‘void QgisApp::showPythonDialog()’:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:894: error:
function ‘void QgisApp::restoreSessionPlugins(QString)’:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:1733: error:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:1737: error:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:1744: error:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:1749: error:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:1752: error:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:1754: error:
function ‘void QgisApp::loadPythonPlugin(QString, QString)’:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:3910: error:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:3923: error:
/Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp:3924: error:
make[2]: *** [src/app/CMakeFiles/qgis.dir/qgisapp.o] Error 1
make[1]: *** [src/app/CMakeFiles/qgis.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 59%] Generating gui/gui.so
make[3]: warning: jobserver unavailable: using -j1.  Add `+' to parent
make rule.
gpsimporterplugin.dir/moc_qgsgpsdevicedialog.o
gpsimporterplugin.dir/qrc_qgsgps_plugin.o
qgswfssourceselect.o
Linking CXX shared module libgpsimporterplugin.so
[ 59%] Built target gpsimporterplugin
[ 60%] Building CXX object src/plugins/wfs/CMakeFiles/wfsplugin.dir/__/
__/__/__/src/app/qgsnewhttpconnection.o
moc_qgswfsplugin.o
moc_qgswfssourceselect.o
moc_qgsnewhttpconnection.o
qrc_wfsplugin.o
Linking CXX shared module libwfsplugin.so
[ 60%] Built target wfsplugin
sipcoreQgsLabelAttributes.cpp: In function ‘PyObject*
meth_QgsLabelAttributes_bufferColor(PyObject*, PyObject*)’:
sipcoreQgsLabelAttributes.cpp:1274: warning: taking address of temporary
[ 61%] Built target python
make: *** [all] Error 2
