[Qgis-developer] QGIS Python support in a library
John C. Tull
john.tull at wildnevada.org
Wed May 28 18:04:07 EDT 2008
With some patches from Jurgen, it is now building. Unfortunately,
python is disabled in the running binary that I built.
John
On May 28, 2008, at 8:54 AM, Tim Sutton wrote:
> Hi Martin
> Thanks for doing this change - I think it will be a nice improvement.
> For me I get this error when trying to build on OSX:
> [ 72%] Built target python
> Linking CXX executable qgis_help.app/Contents/MacOS/qgis_help
> [ 74%] Built target qgis_help
> Linking CXX shared library libqgispython.dylib
> ld: Undefined symbols:
> __ZN14QgsApplication11pkgDataPathEv
> __ZN14QgsApplication19qgisSettingsDirPathEv
> __ZN16QgsMessageOutput19createMessageOutputEv
> __ZN9QgsLogger5debugERK7QStringiPKcS4_i
> /usr/libexec/gcc/i686-apple-darwin8/4.0.1/libtool: internal link edit
> command failed
> /usr/libexec/gcc/powerpc-apple-darwin8/4.0.1/libtool: internal link
> edit command failed
> lipo: can't figure out the architecture type of: /var/tmp//
> cc9EZSsS.out
> make[2]: *** [src/python/libqgispython.0.11.dylib] Error 1
> make[1]: *** [src/python/CMakeFiles/qgispython.dir/all] Error 2
> make: *** [all] Error 2
> Regards
> Tim
> 2008/5/28 Martin Dobias <wonder.sk at gmail.com>:
>> Hi all,
>> as you probably know, until now embedding of Python to QGIS was done
>> directly in the QGIS application sources and the support was
>> implemented using conditional #ifdefs. So when building qgis binary,
>> you got it with or without python. This wasn't a very good solution
>> and was doing problems for packagers since there was no easy way to
>> do
>> optional installation of python support.
>> In my recent commit to trunk (r8530) I've done the embedding in more
>> flexible way. All python support code has been moved to src/python
>> directory and now compiles as "qgispython" library. When QGIS
>> application is started, it checks for the presence of this library
>> and
>> tries to load it and init python support. If something is wrong, the
>> python support (i.e. python plugins and console) is disabled.
>> I've tested this new approach on my ubuntu box with success, but
>> other
>> platforms are untested (I could try it on win, but I don't have
>> access
>> to OS X). So Mac and Win wizards please give it a try to see whether
>> it's working fine there or not. I know that Mac makes difference
>> between shared objects and libraries (MODULE / SHARED option in
>> CMake)
>> but I have no idea which one to choose there so try changing this
>> first if you encounter some problems.
>> Generally I hope it won't produce any great havoc, but one never
>> knows
>> :-) If that works fine, you shouldn't notice any change. If that
>> doesn't work fine, nothing python-related will work. Additionally,
>> this change has no impact on python bindings or plugins.
>> Regards,
>> Martin
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton
> QGIS Project Steering Committee Member - Release Manager
> Visit http://qgis.org for a great open source GIS
> openModeller Desktop Developer
> Visit http://openModeller.sf.net for a great open source ecological
> niche modelling tool
> Home Page: http://tim.linfiniti.com
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
