[Qgis-developer] Ubuntu 8.10 and QGIS 0.11
Carson Farmer
carson.farmer at gmail.com
Thu Nov 6 05:37:59 EST 2008
Alex Mandel wrote:
> Carson Farmer wrote:
>> Alex,
>>>> Alex,
>>>>> Well, it appears to be an issue on only some machines possibly related
>>>>> to video card drivers and X11 not necessarily qt.
>>>>> Both 0.11 and 1.0 kore work on a fresh Ubuntu install (tested in
>>>>> virtual
>>>>> box) so kde libs are not the solution.
>>>>> I have an nvidia gforce 8600gm, and tried both the nv and nvidia(177)
>>>>> drivers, haven't tried plain vga drivers yet.
>>>>> Carson: what video card do you have?
>>>> I have an intel card: Intel Graphics Media Accelerator (GMA) 950
>>>> I have had quite a bit of graphics card trouble with Intrepid, so I
>>>> actually ended up doing a complete reinstall of hardy... Until I hear
>>>> some very promising news saying these issues are resolved, I think I'm
>>>> going to stick with hardy... sorry I can't be of more help...
>>>> Carson
>>> Carson,
>>> Can you just confirm that you were not having the gdal issue that was
>>> causing a segfault and that you were having an issue where the splash
>>> screen stuck at "Setting up GUI"
>> Yes, I can confirm that the issue was with the splash screen stuck at
>> "Setting up GUI"
>> Carson
> Well we're one step closer to solving the issue, ok 647 steps closer,
> I've narrowed down the issue to 647 possible packages and am working
> through them now.
> Carson, Tim if you can diff this list against your installed packages
> and tell me the matches it will speed up the process.
> Here's the list:
> http://trac.osgeo.org/qgis/ticket/1384
Hey Alex, attached is my list of packages that I have installed that are
common to the ones on your list.
I did a fresh install of Hardy the day after I tried to upgrade to
Intrepid however, so my hardy install and packages are all relatively
new, don't know if this will make a difference or not?
Cheers,
Carson
Type: video/dv
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20081106/5a6683fd/common_packages.bin
