[Qgis-developer] more than one geometry column
    Tim Sutton
    tim at linfiniti.com
    Fri Nov  7 02:01:32 EST 2008
Hi
On Thu, 2008-11-06 at 19:49 -0800, Alex Mandel wrote:
8<--------------snip-----------
> I'm curious about adapting this to read wkt columns in sqlite directly,
> I guess I should look at implementing a QgsSQLiteProvider and take some
> hints from yours.
GDAL/OGR already has support for Sqlite (though I think it uses Wkb
rather than Wkt) so you may want to look at writing a front end to that
- the current add layer functionality does not work for cases like
sqlite where you need to select a sublayer after selecting a file. That
said Godofredo Contreras was working on generic access to OGR database
based datasets at one point and it may be good to hook up with him first
and look at collaborating....
Regards
Tim
> Thanks,
> Alex
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20081107/3586041c/attachment.bin
