[Qgis-developer] GRASS db modules
Paolo Cavallini cavallini at faunalia.it
Fri Nov 7 13:59:46 EST 2008
Hi all.
I'm trying to address https://trac.osgeo.org/qgis/ticket/1173
The idea is having in the same window both connection parameters and
login credentials. The current situation is quite confusing.
The problem is that I do not know how/if it is possible to have two
different grass commands in the same module. Anyone knows?
Also, I do not understand why having both db.connect and
db.connect.schema (the second is == to the first, with just one extra
option).
All the best.
Paolo Cavallini, see: * http://www.faunalia.it/pc *
