[Qgis-developer] PyQt compile problem
William Kyngesburye
woklist at kyngchaos.com
Wed Nov 12 10:13:45 EST 2008
Looking closer at that typedef, isn't size_t defined in a system
header? And on 64bit systems, shouldn't it be a 64bit integer? (or am
I thinking of another _t type?) Not a problem yet for OSX, since a
64bit python isn't available (or practical), but on other systems...
On Nov 12, 2008, at 8:57 AM, William Kyngesburye wrote:
> On Nov 12, 2008, at 8:40 AM, Martin Dobias wrote:
>> Hi William,
>> looking at SIP 4.7.8 there are some changes regarding typedefs that
>> probably cause different behaviour. Now in qgsgeometry.sip there's a
>> typedef for size_t inside QgsGeometry class. I guess that new SIP now
>> explicitly tries to use QgsGeometry::size_t and that's not correct.
>> Please try to edit python/core/qgsgeometry.sip file and move "typedef
>> unsigned int size_t;" before definition of the class QgsGeometry. If
>> that helps I'll commit the fix to SVN.
>> Regards
>> Martin
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
