[Qgis-developer] gui
Tim Sutton tim at linfiniti.com
Sun Nov 16 10:49:05 EST 2008
Hi
Usually cmake is good about determining when stuff needs a recompile.
However if it doesnt pick up something try just running cmake or ccmake
again and then compiling. As a last resort use make clean.
Remember that we are in GUI freeze so small tweaks like you have made we
can probably get away with, but do try to avoid changing any visual
parts of the application otherwise you will frustrate the document
writers.
Regards
Tim
On Sun, 2008-11-16 at 16:21 +0100, Borys Jurgiel wrote:
> Hi list,
> I've fixed the .ui file of dxf2shpconverter plugin but I need to `make clean`
> in order to recompile it. Is there any way to force recompiling? If not,
> please remember to make clean before building future packages :)
> Regards,
> B.
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20081116/70e72498/attachment.bin
