[Qgis-developer] gui
Borys Jurgiel
borys at wolf.most.org.pl
Sun Nov 16 19:13:07 EST 2008
> Usually cmake is good about determining when stuff needs a recompile.
> However if it doesnt pick up something try just running cmake or ccmake
> again and then compiling. As a last resort use make clean.
Thanks! So it seems it's necessary to run `make clean` this time.
> Remember that we are in GUI freeze so small tweaks like you have made we
> can probably get away with, but do try to avoid changing any visual
> parts of the application otherwise you will frustrate the document
> writers.
Sure! Note that I haven't change the layout but resizing policy (there was a
bug there and widgets was begining to overlap when resizing).
Regards,
B.
