[Qgis-developer] Proposal: Lift feature freeze for labelling
Jürgen E. Fischer
jef at norbit.de
Sun Oct 5 07:44:56 EDT 2008
Hi Tim,
On Thu, 02. Oct 2008 at 23:45:08 +0200, Tim Sutton wrote:
> If you cast your mind back to our feature plans for QGIS 1.0, one
> sorely needed improvement is a better labelling engine.
+1
We also had a few requests regarding labeling on the INTERGEO qgis booth
- and someone else filed a bug about this meanwhile.
I have attached a patch for #1335 that adds scale based label visibility
and line oriented labels, which might add or interfere with the libpal
integration.
Regarding the GEOS C++ API: porting libpal to the C-API doesn't seem
that hard, so that shouldn't be a (technical) problem.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
