[Qgis-developer] QgsMapLayerRegistry (and QgsMapCanvas) problem
Carson Farmer carson.farmer at gmail.com
Fri Oct 17 10:39:15 EDT 2008
Hello gang,
According to the API, QgsMapLayerRegistry.instance().mapLayers() should
return (in the case of python) a dict with the following format:
{ layer0 : QgsMapLayer, layer1: QgsMapLayer }
However, what I appear to be getting is slightly different. Instead of
QgsMapLayers, I get QgsVectorLayers and QgsRasterLayers. This also
occurs when trying to get a QgsMapLayer from the map canvas. Is this
intended, and if so then this creates a problem:
QgsMapLayer.type() returns (as of 9490-ish) either VectorLayer (0) or
RasterLayer (1) [ QgsMapLayer.LayerType ]
QgsVectorLayer,type() returns either Point (0), Line (1), Polygon (2),
or UnknownGeometry (3) [ QGis.geometryType ]
QgsRasterLayer.type() returns (as far as I can tell) the same as
QgsMapLayer.type(), so: RasterLayer (1)
So the problem is this:
If we are trying to check what type of layers we have in our
QgsMapLayerRegistry, if it's a raster, we will be told that it's a
raster by returning QgsMapLayer.RasterLayer (or 1), however, if it's a
vector, then we will get QgsVectorLayer.type() instead of
QgsMapLayer.type().
I see three solutions to this problem:
a) I'm doing this all wrong, and hopefully someone will tell me this,
b) My favoured solution: Since QgsVectorLayer inherits QgsMapLayer,
QgsVectorLayer.type() should be changed to QgsVectorLayer.vectorType()
c) All of these enumerators should return something other than numbers?
Clear as mud?
Thanks,
Carson
Carson J.Q. Farmer
PhD Fellow
National Centre for Geocomputation (NCG),
John Hume Building,
National University of Ireland, Maynooth,
Co. Kildare,
Ireland.
http://www.carsonfarmer.com
http://www.ftools.ca
