[Qgis-developer] link for msys don't work (compile qgis inwindows)
Marco Pasetti marcopstt at gmail.com
Wed Oct 22 04:17:01 EDT 2008
Alberto,
>Thanks tim, but it's the file which I had found because there is a problem
>with the geos library...
>" You're using deprecated header io.h. Please update your sources according
>to new layout of GEOS headers and namespace "
>The  file install talk about some directories that is not present then I
>think it's not the file correct.
>I'm going to read the section which godofedro talk about
check out the trunk and read the documentation for MS-Windows
(qgis/ms-windows/README.html)
referring to the above documentation, follow the instruction from point 1 to
9 (included)
Regards,
Marco
