[Qgis-developer] Re: [work] Re: QGIS windows build - Alaska
dataset
Marco Pasetti
marcopstt at gmail.com
Tue Sep 16 05:52:15 EDT 2008
Hi Otto,
> I did following change now at http://download.osgeo.org/qgis/data/
> - qgis_sample_data.tar.gz -> 20080329_qgis_sample_data.tar.gz
> (according to the last modified date on the server)
> - qgis_data_2008_09_15.tar.gz -> latest_qgis_sample_data.tar.gz
> If we update the dataset again, I would propose to rename the
> latest_qgis_sample_data.tar.gz to 20080915_qgis_sample_data.tar.gz (again
> according to the last modified date on the server) and name the updated
> dataset
> always latest_qgis_sample_data.tar.gz.
> This would need once a small change in the windows and probably mac
> installer,
> but then it would be clear, which version people should download. Hope
> this
> is ok for you...
that's fine for me. But there's a small problem though. To avoid continuos
changes in the installer script, every time the data set is updated, it
would be better for me if the unpacked name of the folder would be the same
of the tar.gz file . Could you do that change?
Regards,
Marco
