[Qgis-developer] Tagged kore preview 1
William Kyngesburye
woklist at kyngchaos.com
Fri Sep 26 23:44:57 EDT 2008
A bit of a minor problem with Qt 4.4 on OSX, that I haven't seen with
previous versions of Qt: when embedding the Qt frameworks, I reset the
install_names of the interlinked Qt frameworks to relative paths (Tom
does this with his also).
Now with Qt 4.4, this finds the Qt plugins in /Developer/Applications/
Qt/plugins, if they are installed (I don't include the Qt plugins in
my package). These plugins still have their install_names set to find
the installed Qt frameworks, which then causes confusion in the linker
and Qgis crashes on startup with (the first few lines of the trace):
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000010
Thread 0 Crashed:
0 libqtaccessiblewidgets.dylib 0x157be6f7
QAccessibleScrollBar::childCount() const + 17
1 QtGui 0x00eadbca
QAccessible::updateAccessibility(QObject*, int, QAccessible::Event) +
458
2 QtGui 0x00a13054
QWidgetPrivate::show_helper() + 420
This does not happen when the Qt frameworks are not embedded.
Embedding the Qt plugins doesn't help, if they are still also in /
Developer.
Is there some way for Qgis to force Qt to NOT load plugins from /
Developer? Otherwise I must put a warning in the readme about this,
with a recommendation to move/delete the /Developer Qt plugins.
On Sep 22, 2008, at 2:57 PM, Tim Sutton wrote:
> Hi Folks
> I have tagged QGIS Kore preview 1 which you can get by doing:
> svn export https://svn.osgeo.org/qgis/tags/Release-1_0_0-preview1
> The purpose of the tag is to make preview packages against a known
> version of QGIS. If you are a packager please do not replace QGIS
> 0.11.0 in any repositories you manage, but rather create a separate
> standalone package. You can send me the URL of any packages you create
> and I will put a them onto the QGIS download site. Please do not
> commit anything against the tag, its just a marker and not intended to
> become a branch.
> We will give out the URLS to kore preview1 at FOSS4G2008 next week for
> the adventurous who might like to give it a whirl.
> Best regards
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
