AW: [Qgis-developer] Number of features to draw before updating
thedisplay..
bonar
bonar_reddevil at yahoo.com
Tue Apr 7 22:30:29 EDT 2009
Hi Dr.Marco,
Thanks for your quick reply, i'm glad to get my trainer reply my email. I will try the code and will inform you the output.
Thank you so much Dr.Marco,
bonar
Hi Bonar
To update the display after 1000 features, you may do the following:
QSetting s;
s.setValue( "/Map/updateThreshold", 1000);
Like this, the vector layer sends the signal QgsMapLayer::screenUpdateRequested each 1000 features and the slot QgsMapCanvas:: updateMap refreshes the map image. If you are using QgsMapCanvas in your application, the signals of the layers are automatically connected to the refresh slot.
In a similar way, you may set other properties., e.g. to make your map appear nicer, do
s.setValue( "/qgis/enable_anti_aliasing", true);
You might have a look at src/app/qgsoptions.cpp for the other options.
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: qgis-developer-bounces at lists.osgeo.org im Auftrag von bonar
Gesendet: Di 07.04.2009 08:38
An: qgis-developer at lists.osgeo.org
Betreff: [Qgis-developer] Number of features to draw before updating thedisplay..
hi devs and Dr.Marco,
I have a question regarding how can i make a rendering to my vector layer display. Lets me explain a little bit of my scenario; i need to load a building layer that contain a lot of data and it take some time to load. So, my plan is to render it by drawing a certain number of features first before updating the display. It's look like on QGis Edit>>Options>>Rendering>>Rendering Behavior panel and we can set "Number of features to draw before updating the display" = 10000(or some others value).
Hope you guys can help me on this matters.
Thanks in advance,
bonar
View this message in context: http://n2.nabble.com/Number-of-features-to-draw-before-updating-the-display..-tp2597278p2597278.html
Sent from the qgis-developer mailing list archive at Nabble.com.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
View this message in context: http://n2.nabble.com/Number-of-features-to-draw-before-updating-the-display..-tp2597278p2602756.html
