[Qgis-developer] Some questions about PyQGIS
Germán Carrillo carrillo.german at gmail.com
Sun Apr 12 22:29:57 EDT 2009
Hi Martin.
> Someone probably forgot to add this function to python bindings...
> I've revised the bindings and fixed this (and few more missing
> functions) in svn trunk (r10467) and it will be included in version
> 1.1.
> But I don't think setScale() is the right method. In fact it just a
> workaround for map composer to show layers with scale-based visibility
> correctly. I'm not aware of direct method that would do it. You can
> check QgsScaleCalculator code that calculates scale from map extent -
> so you should be able to do inverse calculation.
Thanks, I will check it.
> Yes, you can do it by setting destination CRS in map renderer
> associated with map canvas.
Yes, it works!
> Right :)
> In case you need them, I can create those wrappers...
Please do it, I need them. :)
>> 4. Implementing the QgsMapTool class I have no way to get the DoubleClick
>> event, I did this:
>>     def canvasDoubleClickEvent(self,event):
>>         print "Yes"
>>    But it doesn't work. I get two (Raise) Release events instead of
DoubleClick one.
>> (I really want the DoubleClick event)
> I have no idea about this one. The bindings are in place, so the
> problem might be in dispatch of double click from canvas.
Thank you Martin.
  |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090412/be27c656/attachment.html
