[Qgis-developer] Vector Overlay now in Trunk?
Andreas Neumann
a.neumann at carto.net
Thu Apr 16 11:32:04 EDT 2009
yes - there are the placement algorithm options - as a separate tab in the
QGIS options.
However, I am not so sure if this should be a global setting. Shouldn't
this be layer-specific?
One layer probably should use this placement algorithm, while a different
layer might require a different placement algorithm. As an example a layer
with fewer diagrams may want to use a more sophisticated algorithm, while
a layer with lots of diagrams may want to use a faster algorithm. Also,
there may be different quality requirements for different layers or
projects.
So in my opinion the algorithm choice should be layer specific. Any
thoughts on why this is not a good idea?
Andreas
On Thu, April 16, 2009 4:28 pm, Borys Jurgiel wrote:
> W czwartek, 16 kwietnia 2009 roku o godzinie 16:18:40 ³askaw(a) by³(a)
> Pan(i)
> rzec:
>> yeah - you are right. I did not enable the plugin "Diagram Overlay"
>> Seems to work now - thanks!
> There is something more - a new tab in the main 'Options' dialog
> containing a
> placement method. However I can't figure out if/how it works... I'm sure
> Marco
> was speaking about it in Hannover, but I evidently missed it...
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
