[Qgis-developer] Segmentation fault
Lynx lynx21.12.12 at gmail.com
Thu Apr 23 12:38:05 EDT 2009
Hi list,
I checked out QGis "Pan" from svn revision 10634. And i got the segmentation fault when launched it:
Python support ENABLED :-)
Debug: /usr/local/src/qgis_pan/src/app/qgspluginregistry.cpp: 396: (checkCppPlugin) Failed to get name, description, or type for /usr/local/lib/qgis/libdelimitedtextprovider.so
Debug: /usr/local/src/qgis_pan/src/app/qgspluginregistry.cpp: 396: (checkCppPlugin) Failed to get name, description, or type for /usr/local/lib/qgis/libgpxprovider.so
Debug: /usr/local/src/qgis_pan/src/app/qgspluginregistry.cpp: 396: (checkCppPlugin) Failed to get name, description, or type for /usr/local/lib/qgis/libgrassprovider.so
Debug: /usr/local/src/qgis_pan/src/app/qgspluginregistry.cpp: 396: (checkCppPlugin) Failed to get name, description, or type for /usr/local/lib/qgis/libmemoryprovider.so
Debug: /usr/local/src/qgis_pan/src/app/qgspluginregistry.cpp: 396: (checkCppPlugin) Failed to get name, description, or type for /usr/local/lib/qgis/libogrprovider.so
Program received signal SIGSEGV, Segmentation fault.
0x00efc615 in QWidgetPrivate::init (this=0x8861578, parentWidget=0x86ac3b8,
    f=@0xbfffe8dc) at /var/tmp/qt-x11-src-4.5.0/src/gui/kernel/qwidget.cpp:1059
1059        if (parentWidget && parentWidget->windowType() == Qt::Desktop) {
Missing separate debuginfos, use: debuginfo-install OpenEXR-libs-1.6.1-4.fc10.i386 OpenSceneGraph-libs-2.6.0-1.fc10.i386 OpenThreads-2.6.0-1.fc10.i386 PyQt4-4.4.4-5.fc10.i386 atlas-3.6.0-15.fc10.i386 bzip2-libs-1.0.5-3.fc10.i386 cfitsio-3.130-3.fc10.i386 cyrus-sasl-lib-2.1.22-19.fc10.i386 dbus-libs-1.2.4-2.fc10.i386
