[Qgis-developer] python plugin translations
Borys Jurgiel
borysiasty at aster.pl
Thu Apr 23 19:10:24 EDT 2009
Thursday 23 of April 2009 18:32:04 Alex Mandel napisał(a):
> I asked briefly on IRC the other day if there was a "how to" for
> including translation strings in a plugin, but no one seemed to know of
> such a thing. I'd like to allow for translation of my plugin but I'm not
> sure where to start.
I'm not sure if it makes any sense because I'm extremely sleepy, but here is
what I've just written to Maxim. Note that I never did it, but it should work.
There are two different approaches:
A. For external plugins, you can translate them 'locally': all the translation
stuff is inside the plugin directory and it links to qgis in the runtime. It
doesn't affect the main qgis .ts files, so the plugin maintainer has to keep an
eye on the translations and ask the translators.
Unfortunately I didn't ever try it. At the time there is one plugin
implementing such internalization. It's Horst's Geoprocessing. Use the code as
an example. In general, you need to:
1) Pass all strings through the QCoreApplication.translate("context","text")
static method. Maybe you can use just self.tr("text") instead, but I'm not sure
whether it works in this case - it may be not able to pass the strings to the
application. Please pay attention for a text context. It's very hard for
translators to deal with text with enigmatic context. Usually the context is
just the name of the class where the string is used. So it's very important to
give classes a 'translator-friendly' ;) names, like "QgsReprojectRasterDialog"
instead of just a "Dialog".
2) Create a .pro file and run pylupdate, which catches all the tr() parameters
from both .py and .ui files (given in the .pro file) and create all the local
.ts files. Translate the .ts files and compile them to .qm
3) Init and connect the QTranslator() object - look at the begining of Horst's
geoprocessing.py file.
B. For 'internal' plugins, like fTools placed in svn, it's much simpler. You
just need to use the self.tr() or QCoreApplication.translate() methods in .py
files. All such strings in .py and .ui will be catched by the
qgis/update_ts_files.sh script and put to the main qgis .ts files.
