[Qgis-developer] Import error in the qgis.core, qgis.gui module, Help needed
Giovanni Manghi giovanni.manghi at gmail.com
Mon Apr 27 07:07:45 EDT 2009
> Hi Jürgen,
> Thanks for your reply, but I don't get your idea. Do you mean that I have to
> include into the path variable only the C:\OSGeo4W dir?
> Please explain more (if you can)
I had once a similar problem and I noticed that if pyhton is already
installed this interferes with the osgeo4w installation.
I removed it, installed what I needed via osgeo4w, including python,
than re-installed pyhton and all worked fine. I don't know if there is a
simpler workaround.
See also:
http://trac.osgeo.org/osgeo4w/ticket/65#comment:11
-- Giovanni --
