[Qgis-developer] problem in projection
Bijay Panda
bijaykumar.mail at gmail.com
Tue Apr 28 07:25:52 EDT 2009
Thanks for your reply.
But that expand option(+) is not there which means there might be some other
problem .I am not getting what could be the problem.I checked all the
settings.
plz give me any suggestion.
On Tue, Apr 28, 2009 at 4:45 PM, Carson Farmer <carson.farmer at gmail.com>wrote:
> Hi Bijay,
>> Hi All,
>> I am using Qgis 1.0.0 in ubuntu 8.04.Actually after loading a Raster layer
>> when i try to select
>> change co-ordinate Reference system (CRS)in project properties it shows
>> only three i.e Geographic co-ordinate system
>> Projected co-ordinate system
>> User defined co-ordinate system
> You will need to expand one of the above tree items to view the CRS under
> them... to do this, click the + symbol and select the CRS you want (you will
> have to know whether it is a Geographic, Projected, or User defined CRS).
> You can also use the search tools to help you find the CRS you are looking
> for...
> Carson
> Carson J. Q. Farmer
> ISSP Doctoral Fellow
> National Centre for Geocomputation (NCG),
> Email: Carson.Farmer at gmail.com
> Web: http://www.carsonfarmer.com/
> http://www.ftools.ca/
Thanks & Regards
Bijay Kumar Panda
Mob-9739591816
bijaykumar_panda at yahoo.com
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090428/4a832251/attachment-0001.html
