[Qgis-developer] QGIS 1.1 testing
Alex Mandel
tech_dev at wildintellect.com
Wed Apr 29 05:23:44 EDT 2009
Martin Dobias wrote:
> On Wed, Apr 29, 2009 at 2:42 AM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> GRASS Plugin always starts off for some reason.
>> GRASS opening the toolbox give a /grass/config/default.qgc not found.
>> Hence module List etc are missing.
>> (I'm guessing I missed something in the grass-plugin build)
>> -Tried both libgdal1-dev 1.6.0-1 and libgdal1-dev 1.5.4-2
>> -These are working fine in my repo pulled versions of qgis
>> -tried with GRASS 6.3 and custom 6.4
> I think some files from older QGIS installation cause this problem.
> Clean the installation directory and do 'make install' again.
> Martin
I wish that were the case, but each of these attempts was installed to
it's own path.
/apps/qgis1.1
/apps/qgis-trunk
etc...
I also made sure to run make clean if reattempting and in some cases
completely removed build and started over.
Alex
