[Qgis-developer] Addition to QgsRenderContext
Magnus Homann magnus at homann.se
Tue Aug 4 11:29:05 EDT 2009
Is it OK to add transparency setting into the render context? This would make it much easier to
cache point symbols with transparency.
Current contents:
     /**Painter for rendering operations*/
     QPainter* mPainter;
     /**For transformation between coordinate systems. Can be 0 if on-the-fly reprojection is not used*/
     QgsCoordinateTransform* mCoordTransform;
     /**True if vertex markers for editing should be drawn*/
     bool mDrawEditingInformation;
     QgsRectangle mExtent;
     /**If true then no rendered vector elements should be cached as image*/
     bool mForceVectorOutput;
     QgsMapToPixel mMapToPixel;
     /**True if the rendering has been canceled*/
     bool mRenderingStopped;
     /**Factor to scale line widths and point marker sizes*/
     double mScaleFactor;
     /**Factor to scale rasters*/
     double mRasterScaleFactor;
     /**Map scale*/
     double mRendererScale;
