[Qgis-developer] OGRSpatialReference problem in QGIS
Florian Hillen
fhillen at uni-osnabrueck.de
Mon Aug 17 10:42:13 EDT 2009
Hi list,
I have a problem with OGR in Quantum GIS.
For my Plugin which reprojects rasterdata to another CS, I need a WKT
description of the new CS. With the QgsProjectionSelector I can select a
CS and read out the epsg code or the proj4 string. But I fail by setting
this to an OGRSpatialReference and export that to a WKT.
If I transform a 4326 scene with my plugin to 31467 (german system), the
gdal warp works correctly (the coordinates are right), but the information
about the geocs looks like this:
PROJCS["unnamed",PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],PARAMETER["scale_factor",1],PARAMETER["false_easting",3500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
Here is the code in which I set the OSR:
OGRSpatialReference oSRS;
long epsg = projectSelector->selectedEpsg();
if(epsg == 0)
return false;
if(epsg == 4326)
QString epsgString;
epsgString.setNum(epsg);
epsgString.prepend("EPSG:");
oSRS.SetWellKnownGeogCS(epsgString.toUtf8());
else
oSRS.SetProjCS((projectSelector->selectedName()).toUtf8());
oSRS.importFromProj4((projectSelector->selectedProj4String()).toUtf8());
oSRS.exportToWkt( &pszDstWKT );
The if-clause for 4326 was just a try to use an other function, so don't
focus on that too much.
Can anyone help me with that?
Do I have to use the C-API for that? I already had problems with the C++
API of GDAL in Quantum GIS. My first attempt with the C-API for OGR wasn't
successful either, that's why I asked you for a hint.
Thanks in advance and best regards,
Florian
