[Qgis-developer] Re: symbology-ng build
Martin Dobias
wonder.sk at gmail.com
Mon Aug 17 20:17:51 EDT 2009
On Tue, Aug 18, 2009 at 2:12 AM, John C. Tull<jctull at gmail.com> wrote:
> That seems to have worked and things are getting farther:
> Creating qgisconfig.py...
> Done
> [ 60%] Generating core/core.so
> /System/Library/Frameworks/Python.framework/Versions/2.5/share/sip/PyQt4/QtCore/qlist.sip:
> In function ‘int
> convertTo_QList_27000600QList_0200QgsSymbolV2LevelItem(PyObject*, void**,
> int*, PyObject*)’:
> /System/Library/Frameworks/Python.framework/Versions/2.5/share/sip/PyQt4/QtCore/qlist.sip:85:
> error: ‘sipType_QgsSymbolV2Level’ was not declared in this scope
> /System/Library/Frameworks/Python.framework/Versions/2.5/share/sip/PyQt4/QtCore/qlist.sip:103:
> In function ‘PyObject*
> convertFrom_QList_27000600QList_0200QgsSymbolV2LevelItem(void*, PyObject*)’:
> /System/Library/Frameworks/Python.framework/Versions/2.5/share/sip/PyQt4/QtCore/qlist.sip:59:
Try again with r11421.
Cheers
Martin
