[Qgis-developer] Delay in release
lists at linfiniti.com lists at linfiniti.com
Sat Aug 22 01:34:53 EDT 2009
Hi All
I havent quite tagged the release yet as I am experiencing a problem
with the win build:
Build Log      Build started: Project: svnversion, Configuration:
RelWithDebInfo|Win32
 Command Lines      Creating temporary file
"C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\BAT000006476900.bat" with contents
@echo off
cd ..
C:
for /f usebackq %%a in "(`C:/Program
Files/Subversion/bin/svnversion.exe`)" do echo #define QGSSVNVERSION
"%%a" >C:/dev/cpp/qgis_trunk/build/qgssvnversion.h
if errorlevel 1 goto VCReportError
goto VCEnd
:VCReportError
echo Project : error PRJ0019: A tool returned an error code from
"Generating qgssvnversion.h"
exit 1
:VCEnd
Creating command line
I will probably tag the branch today (Sat 22 Aug) once I have figured
out what is causing the above.
Sent via my BlackBerry from Vodacom - let your email find you!
