[Qgis-developer] The plain keys for shortcuts
William Kyngesburye
woklist at kyngchaos.com
Sun Aug 23 15:10:46 EDT 2009
The source file where the shortcut defaults are setup can be
conditionalized on the platform, and some already are, but only to not
define a shortcut that would conflict with the system (like cmd-H on
OSX = hide app).
I considered doing that for the bugfix, but then default shortcuts
wouldn't be consistent across platforms.
On Aug 23, 2009, at 1:44 PM, John C. Tull wrote:
> This is beyond my knowledge on how these shortcuts can be set in the
> build environment, but it sounds like there needs to be a system
> check at compile time and different keyboard shortcuts should be set
> based on the OS. I think someone said this was not possible. Is that
> correct?
> John
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
