[Qgis-developer] Accessing Features from API
ahmed at elegantdesigns.ca
Mon Aug 24 13:26:47 EDT 2009
The output of the attached code is:
Layer: "test_shp_layer"
field: "test_shp_field"
v_provider: "<qgis.core.QgsFeature object at 0xab50dac>"
rows: []
Even if I add a dummy string to the list, it will only return that value.
For some reason, I cannot seem to fetch the features from the layer and
load them into the list. I was wondering, what did my fragile brain do
wrong? and how can i fix it?
cheers,
dassouki
# CODE:
# loads a field into a python list
def field_to_list( self, layer_name, field_name ):
v_layer = self.get_vector_layer_by_name( layer_name ) )
v_provider = v_layer.dataProvider()
id = v_provider.fieldNameIndex( field_name )
rows = []
feat = QgsFeature()
while v_provider.nextFeature( feat ):
data = feat.attributeMap()[ id ]
row = [ data ]
rows.append( row )
QMessageBox.warning( self, "window title", str( ",".join( rows ) ) )
return rows
def get_vector_layer_by_name( self, myName ):
layermap = QgsMapLayerRegistry.instance().mapLayers()
for name, layer in layermap.iteritems():
if layer.type() == QgsMapLayer.VectorLayer and layer.name() ==
myName:
if layer.isValid():
return layer
else:
return None
