[Qgis-developer] Accessing Features from API
ahmed at elegantdesigns.ca ahmed at elegantdesigns.ca
Tue Aug 25 07:55:04 EDT 2009
Motta,
I'd love to see those sources
p.s. thank you to jef(IRC) and Germán for helping me out. It was
invaluable
cheers,
dassouki
On Tue, 25 Aug 2009 08:12:06 -0300, "motta.luiz at gmail.com"
<motta.luiz at gmail.com> wrote:
> You need define which field you want get by call attributeMap.
>     id = v_provider.fieldNameIndex( field_name )
>     v_provider.select([id]) # Define field you get attribute
>     rows = []
>     feat = QgsFeature()
>     while v_provider.nextFeature( feat ):
>       data = feat.attributeMap()[ id ]
>       row = [ data ]
>       rows.append( row )
> PS: I made some sources for study case, if you want i can send for you.
> ahmed at elegantdesigns.ca escreveu:
>> The output of the attached code is:
>> Layer: "test_shp_layer"
>> field: "test_shp_field"
>> v_provider: "<qgis.core.QgsFeature object at 0xab50dac>"
>> rows: []
>> Even if I add a dummy string to the list, it will only return that
value.
>> For some reason, I cannot seem to fetch the features from the layer and
>> load them into the list. I was wondering, what did my fragile brain do
>> wrong? and how can i fix it?
>> cheers,
>> dassouki
>> # CODE:
>>   # loads a field into a python list
>>   def field_to_list( self, layer_name, field_name ):
>>     v_layer = self.get_vector_layer_by_name( layer_name ) )
>>     v_provider = v_layer.dataProvider()
>>     rows = []
>>     feat = QgsFeature()
>>       row = [ data ]
>>       rows.append( row )
>>     QMessageBox.warning( self, "window title", str( ",".join( rows ) ) )
>>     return rows
>>   def get_vector_layer_by_name( self, myName ):
>>     layermap = QgsMapLayerRegistry.instance().mapLayers()
>>     for name, layer in layermap.iteritems():
>>       if layer.type() == QgsMapLayer.VectorLayer and layer.name() ==
>> myName:
>>         if layer.isValid():
>>           return layer
>>         else:
>>           return None
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
