[Qgis-developer] Re: [Qgis-user] symbol lookup error:
/usr/lib/libqgisgrass.so.1.2.0: undefined symbol: G_no_gisinit
Jürgen E. Fischer
jef at norbit.de
Sat Aug 29 08:36:18 EDT 2009
Hi Goyo,
On Sat, 29. Aug 2009 at 12:06:24 +0200, Goyo wrote:
> Packages in ubuntugis-unstable[2] are working for me, even after with
> libgdal1-1.6.0-grass installed. Packages in
> qgis-unstable-ubuntugis-jef[3] cause the symbol lookup error, even if
> they have the same version number.
qgis-unstable-ubuntugis-jef is just for test builds. After the builds
succeeded they were copied to unstable-ubuntugis.
So it's virtually impossible that the packages in unstable-ubuntugis work any
different than those from qgis-unstable-ubuntugis-jef. They are the same.
You probably didn't consider that the qgis-unstable-ubuntugis-jef repository
depends on unstable-ubuntugis. So you need the latter in any case. And as
it already contains the packages from qgis-unstable-ubuntugis-jef, you don't
need my test repository at all.
But just using qgis-unstable-ubuntugis-jef will probably give you the right
qgis, but some older dependencies from plain ubuntu - looks like that doesn't
work. But that was never intended anyway.
If you don't want ubuntugis the qgis unstable ppa[1] has packages that work
with plain ubuntu.
hth
Jürgen
[1] https://launchpad.net/~qgis/+archive/unstable
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
