[Qgis-developer] Python QGis Geometry.transform
motta.luiz at gmail.com
Thu Dec 3 08:53:45 EST 2009
Barry,
Thank´s your menssage.
I can use this :
pt = transformer.transform(point)
But i need change all point in Geometry object, then, i would like make
this with direct core QGIS by
feat = self.__createFeature(dicAttribute) # function return Feature
coordTrans = core.QgsCoordinateTransform(coordRSLyr, coordRSIntersects)
feat.geometry().transform(coordTrans) # QgsGeometry::transform Not
Implement in PYTHON!
Barry Rowlingson escreveu:
> On Thu, Dec 3, 2009 at 1:06 PM, motta.luiz at gmail.com
> <motta.luiz at gmail.com> wrote:
>> Hi All,
>> I need transform geometry of one feature to other reference system.
>> The API of geometry show the method transform
>> int QgsGeometry::transform(const QgsCoordinateTransform)
>> But in the Python, this methdos not exist.
>> Console Python QGis
>>> from qgis import
>>> core geom = core.QgsGeometry()
>>> print dir(geom.transform)
>> exceptions.AttributeError: 'QgsGeometry' object has no attribute 'transform'
>> I tested with:
>> Ubuntu 9.10, QGis 1.3.0-Mimas code revision "exported"
>> Windows XP, QGis 1.3-Mimas code revision 11638
>> Do someone use this method in Python ?
> I think you need to use QgsCoordinateTransform - here's a snippet
> from the GeoCoding plugin that transforms a point 'point' from
> whatever proj4string is to EPSG:4326 to 'pt'.
> t=QgsCoordinateReferenceSystem()
> t.createFromEpsg(4326)
> f=QgsCoordinateReferenceSystem()
> f.createFromProj4(proj4string)
> transformer = QgsCoordinateTransform(f,t)
> Barry
