[Qgis-developer] Re: Running two QGIS versions side by side
Craig Leat craig.leat at gmail.com
Mon Dec 7 11:05:52 EST 2009
Jürgen wrote:
>On Mon, 07. Dec 2009 at 16:08:22 +0200, Craig Leat wrote:
>> So it seems that the PPA GRASS lib gets preference. Thanks for any pointers,
>If you install the grass plugin /usr/bin/qgis becomes a shell script that sets
>LD_LIBRARY_PATH, which overrides you ld.so.conf.
Thanks for the tip Jürgen! Solved by setting LD_LIBRARY_PATH first and
then launching QGIS trunk in a script.
Craig
