[Qgis-developer] dted datagrid
Luca Pascale
pascale.luca.it at gmail.com
Tue Dec 8 08:22:45 EST 2009
hi all,
I have a lot of DTED data slice.
I want to load them in qgis and use the elevation data to do some
computation in a plug-in.
Inside the plugin I would want to get the elevation data specifing the
lower-left and upper right corner(in lat/lon) of a grid of elevation data.
My problems are:
1) the points of the grid can, in general, belong to different layer (each
dted slice is a layer), so how to correctly select this points from the
layerset.
2) For a data grid of elevation point I would want also specifies the number
of points for each side of the grid, so probably an interpolation is needed.
Any suggestions?
Thanks in advance
Luca
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091208/d6347506/attachment.html
