[Qgis-developer] Compilation error with r12446
Jürgen E. Fischer jef at norbit.de
Mon Dec 14 04:09:38 EST 2009
On Mon, 14. Dec 2009 at 10:57:02 +0200, Mailing Lists wrote:
> Try to update and compile again. When you get this type of error you
> can always try to run ccmake .. then press g to regenerate the
> makefiles. Then compile anew.
touch CMakeLists.txt should also help.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
