[Qgis-developer] Enhanced georeferencer plugin
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Wed Feb 4 11:11:52 EST 2009
Great, that was fast!  I have a few scanned historical maps which I have not yet warped with the manual way so I will for sure test the plugin immediately when I can get it for Windows.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: Maxim Dubinin [mailto:sim at gis-lab.info]
> Lähetetty: 4. helmikuuta 2009 18:08
> Vastaanottaja: Rahkonen Jukka
> Kopio: qgis-developer at lists.osgeo.org
> Aihe: Re: [Qgis-developer] Enhanced georeferencer plugin
> Dear Jukka,
> this functionality is already implemented in new Georeferencer plugin.
> You can grab a copy for Ubuntu from svn mentioned here [1] or
> wait for new 1.0.1 (?) release of QGIS, where it will be part
> of standard distribution.
> http://gis-lab.info/qa/qgis-georef-new-eng.html
> Meanwhile, we'll be glad to hear from you regarding any
> problems with this plugin.
> Best regards,
>  Maxim                          mailto:sim at gis-lab.info
> Вы писали 4 февраля 2009 г., 7:07:52:
> RJ> Hi,
> RJ> This message has been lying for some days in QGis forum and now I
> RJ> was adviced to send it to mailing list.
> RJ> -Jukka Rahkonen-
> RJ>
> RJ> Forum message follows:
> RJ> "The Georeferencer plugin is pretty nice to use. However, I have
> RJ> found that the result of georeferencing with world file is not
> RJ> always satisfactory. Therefore I have used the fine user
> interface
> RJ> for collecting ground control points and done the rest of
> RJ> georecerencing with other tools. However, I believe that
> it should
> RJ> be rather easy to modify the Georeferencer plugin so that
> it could
> RJ> do georeferncing also with this alternative way. As a result QGis
> RJ> would have a georeferencing tool of professional quality
> both when
> RJ> it comes to easy of use and accuracy.
> RJ> The work flow would be like this:
> RJ> 1. Ground control points are collected with the existing plugin.
> RJ> It is gathering all the information that is needed for
> the next step
> RJ> (mapX, mapY, pixelX, pixelY) 2. Ground control points are fed for
> RJ> gdal_translate program as -gcp parameters. Gdal_translate
> takes them
> RJ> in this order:
> RJ> [-gcp pixel line easting northing [elevation]]* The whole
> RJ> gdal_translate command line would be gdal_translate -of
> GTiff -gcp
> RJ> [params_1] -gcp [params_2] -gcp [params_3] .... input.tif
> RJ> temporary.tif 3. Third step is to warp the temparary image that
> RJ> contains now the ground control points. It is done with gdalwarp,
> RJ> for example like this:
> RJ> gdalwarp -of GTiff -s_srs epsg:4326 -t_srs epsg:4326
> temporaty.tif
> RJ> warped.tif Command lines are presented as working
> examples which can
> RJ> be repeated with gdal utility programs. For the plugin it
> would be
> RJ> better to call gdal funtions directly, use virtual raster
> format as
> RJ> temporary format instead of tiff etc. I cannot say very
> much about
> RJ> how it should be done because I can't program myself.
> RJ> However, in the very end of this link
> RJ> http://www.scangis.org/scangis2007/papers/r3_rahkonen.pdf
> there is
> RJ> python code that might be useful and that can be used
> freely. That
> RJ> script is doing basically the same thing, it takes ground control
> RJ> points from external source and warps image automatically
> with gdal components."
> RJ> _______________________________________________
> RJ> Qgis-developer mailing list
> RJ> Qgis-developer at lists.osgeo.org
> RJ> http://lists.osgeo.org/mailman/listinfo/qgis-developer
