[Qgis-developer] qgsprojectionselector.cpp throws compiler error
Jürgen E. Fischer jef at norbit.de
Thu Feb 5 09:55:13 EST 2009
Hi Horst,
On Thu, 05. Feb 2009 at 15:00:14 +0100, Düster Horst wrote:
> I'm trying to compile r10100 but the new qgsprojectionselector.cpp throws a
> compiler error.
> In file included from /usr/local/src/sogis/qgis_src/trunk/src/gui/
> qgsprojectionselector.h:14,
> from /usr/local/src/sogis/qgis_src/trunk/python/gui/
> qgsprojectionselector.sip:10:
> /usr/local/src/sogis/qgis_src/trunk/src/ui/ui_qgsprojectionselectorbase.h:28:
> error: expected constructor, destructor, or type conversion before "class"
> /usr/local/src/sogis/qgis_src/trunk/src/ui/ui_qgsprojectionselectorbase.h:170:
> error: expected class-name before »{«-character
Not reproducable here.  ui_qgsprojectionselectorbase.h should be
generated by moc during build in your build directory.  Are you building
inplace?
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
