[Qgis-developer] fTools problem on OS X
Aaron Racicot aaronr at z-pulley.com
Fri Feb 6 02:35:18 EST 2009
The old version of my "threading" plugin strikes again.  Talked with Gary on
IRC and removing the plugin resolved the issue and ftools installed fine.
There was a naming conflict with the pre-QGIS1.0 version of the plugin that
causes this issue when installed.  If you have that old "threading" plugin
installed on your system I suggest you remove it.  The new plugin is called
threading_demo to avoid this conflict moving forward.  Thankfully not many
people played with that one ages ago...
Aaron
-----Original Message-----
[mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Gary Sherman
Sent: Thursday, February 05, 2009 9:50 PM
To: qgis-developer List
Subject: [Qgis-developer] fTools problem on OS X
Just tried to install fTools from Carson's repo and get:
Couldn't load plugin fTools due an error when calling its
classFactory() method
   File "", line 1, in
   File "/Users/gsherman/.qgis//python/plugins/fTools/__init__.py",
line 33, in classFactory
     from fTools import fToolsPlugin
   File "/Users/gsherman/.qgis//python/plugins/fTools/fTools.py", line
46, in
     import doIntersectLines, doJoinAttributes, doSelectByLocation,
doVectorSplit, doMeanCoords
   File "/Users/gsherman/.qgis/python/plugins/fTools/tools/
doJoinAttributes.py", line 38, in
     import struct, itertools, datetime, decimal, ftools_utils
   File "/Library/Frameworks/Python.framework/Versions/2.5/lib/
python2.5/decimal.py", line 408, in
     if hasattr(threading.currentThread(), '__decimal_context__'):
AttributeError: 'module' object has no attribute 'currentThread'
-gary
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Chair, QGIS Project Steering Committee
-Micro Resources: http://mrcc.com
   *Geospatial Hosting
   *Web Site Hosting
-Desktop GIS Book:
   *http://desktopgisbook.com
"We work virtually everywhere"
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
