[Qgis-developer] OSM intergration: first public release
John C. Tull
john.tull at wildnevada.org
Sat Feb 7 18:48:01 EST 2009
> On Feb 7, 2009, at 2:17 PM, Martin Dobias wrote:
>> I would consider this as alpha release, but it should be already
>> usable for some basic usage.
>> Any testing and comments are highly welcome!
> Martin,
> Another great addition! This is already quite useful.
> Some quick thoughts after a brief test.
> 1) It would be nice to have the option to automatically load a
> retrieved osm file when using the download feature.
> 2) The loaded osm layers are assigned the CRS of the current
> project. It should be set to the osm default (EPSG 4326, I assume)
> 3) Because there is no apparent CRS transform when the server
> request is made, it appears from my brief test that the project has
> to be WGS84 in order to download OSM data for the canvas extents.
> Using a UTM CRS retrieved empty osm files.
> 4) Even though a dialog is presented to allow the user to overwrite
> a file from the download widget, when you hit the download button,
> an error is given saying a file of that name already exists.
> 5) If you are able to overwrite a file, the associated db file
> probably needs to be removed also.
I also just noticed that trying to identify or select a line feature
shows or selects all features. Maybe you covered this in your email.
This seems strange, because I can classify "highways" with unique
symbology, but I cannot use the Identify Feature tool on those unique
items.
Cheers,
John
