[Qgis-developer] Re: Xcode - compile error, doc questions
Gary Sherman
sherman at mrcc.com
Sun Feb 8 17:27:21 EST 2009
On Feb 8, 2009, at 8:37 AM, William Kyngesburye wrote:
> Well, I decided to start from scratch. My old Xcode project was pre-
> cmake and too many files and targets moved around. And a change in
> the way Xcode processes C++ compilation made me think I had used the
> wrong project template.
> I have the core Qgis libs and app, and all but one of the providers/
> plugins, working.
> For some reason, the north arrow plugin won't compile. With
> moc_plugingui.cpp, plugin.cpp and plugingui.cpp sources I get:
> plugingui.h:21: error: expected class-name before '{' token
Try adding:
#include <QDialog>
after the line containing #include "ui_pluginguibase.h"
> I have found that Xcode (and when compiling in a Terminal) often
> quietly ignores missing headers, but I think that's OK here. Same
> compilation command as in a cmake build (though I could be
> overlooking something), and same Xcode target configuration as all
> the other [working] plugins. I don't know how to track down an
> error like this...
> A couple questions about the documentation.
> - What is help_viewer app needed for? The "Help Index" from the
> Help menu opens said index in Safari. The pdf userguide is linked
> from that index. If the help_viewer is what is opening Safari,
> seems like that should just be done directly by Qgis.
It is used to view context help from within the various dialogs in QGIS.
> - A suggestion: have the userguide pdf directly accessible from the
> Help menu - saves an application switch.
> - I notice that the userguide.pdf is from v0.9.1. Shouldn't this
> have been updated before the 1.0 release?
Yes, I noticed this too. The current 1.0 documentation should have
been included, something that can't be fixed on the next maintenance
release.
> On Feb 3, 2009, at 10:42 AM, William Kyngesburye wrote:
>> I can dust off my old Xcode project, and it shouldn't be too hard
>> to update it to try it out with the 1.0 source and Xcode 3. I have
>> a Tiger Mac also with Xcode 2.5, so I can test project backward-
>> compatibility.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "The beast is actively interested only in now, and, as it is always
> now and always shall be, there is an eternity of time for the
> accomplishment of objects."
> - the wisdom of Tarzan
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Chair, QGIS Project Steering Committee
-Micro Resources: http://mrcc.com
*Geospatial Hosting
*Web Site Hosting
-Desktop GIS Book:
*http://desktopgisbook.com
"We work virtually everywhere"
