[Qgis-developer] Re: [Qgis-user] New Plugin builder
Florian Hillen
fhillen at uni-osnabrueck.de
Sun Feb 22 08:50:48 EST 2009
Hi Gary,
it works really fine now, thanks for that!
I would be glad to see a C++ plugin builder too ;)
But your site is very helpful for prospectiv python-developers I think!
Best regards,
Florian
> I have created a web-based tool to build a minimal QGIS Python plugin.
> Basically you specify the required parameters and it creates a ready
> to run plugin with an blank dialog. The tool compiles the resource and
> Ui files and packages it all up into a zip file for download.
> You can try the builder at: http://pyqgis.org/builder/plugin_builder.py
> The zip file contains a Makefile which can be used to recompile the Ui
> and resource files if you change them. The builder uses Qt 4.4,
> however the generated plugin should work on any QGIS 1.0 install.
> If you've been wanting to develop QGIS plugins but didn't know where
> to start, this tool can get you started quickly by setting up the
> structure for you.
> Comments and suggestions are welcomed.
> -gary
> -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
> Gary Sherman
> Chair, QGIS Project Steering Committee
> -Micro Resources: http://mrcc.com
> *Geospatial Hosting
> *Web Site Hosting
> -Desktop GIS Book:
> *http://desktopgisbook.com
> "We work virtually everywhere"
> Qgis-user mailing list
