[Qgis-developer] buffer segmentation fault
Carson Farmer
carson.farmer at gmail.com
Thu Jan 8 07:31:45 EST 2009
Hello again,
Quick question for the list before I submit a bug...
Is anyone else getting a segmentation fault when attempting to buffer
features (points, lines, or polygons)? It is possible this is a GEOS
issue, but I'm not sure...
Here is some sample code to try in the python console if you want to
confirm the above behaviour (assumes your target layer is the first
layer in your TOC):
>>> map_canvas = iface.mapCanvas()
>>> layer = map_canvas.layer( 0 )
>>> provider = layer.dataProvider()
>>> all_attributes = provider.attributeIndexes()
>>> provider.select( all_attributes )
>>> feature = QgsFeature()
>>> provider.nextFeature( feature )
>>> geometry = feature.geometry()
>>> buffer = geometry.buffer( 500, 5 ) #replace with some relevant value...
and here QGIS closes unexpectedly, leaving the following in the console:
Python support ENABLED :-)
Loaded : Plugin Installer (package: plugin_installer)
Loaded : fTools (package: fTools)
Segmentation fault
Cheers,
Carson
