[Qgis-developer] raster algebra plugin - numpy/Numeric problem
Arpita Singh
singarpita at gmail.com
Fri Jan 9 23:12:50 EST 2009
hello,
I want to build QuickPrint Option Window For my app, where it display
the window as in Quantum Gis of adding north arrow ,title, legend and logo..
I am new in this so plz help by giving some code in python.
i know there must be solution with you all, thanks in advance.
arpita
On Sat, Jan 10, 2009 at 12:14 AM, Barry Rowlingson <
b.rowlingson at lancaster.ac.uk> wrote:
> Okay, so I'm getting my new raster algebra plugin working. Runs fine
> at home on Windows with Qgis 1.0.0-preview2.
> I try it on Linux, on Qgis 1.0.0-Kore. Fails because of API changes,
> so I fix those. Then it fails while playing with raster data from
> gdal.
> What seems to be happening is that on Windows, everything uses numpy
> arrays - so when I get raster data via python-gdal I get a numpy array
> back, which I then manipulate using numpy functions, and pass it back
> to python-gdal to write a new geoTiff. But with Ubuntu, I get a
> Numeric array back, manipulate it with numpy functions, and then pass
> a numpy array to python-gdal which promptly complains that the object
> doesn't have a 'typecode' method (which only Numeric arrays have).
> I think the change happened between python-gdal 1.4 and 1.5. Is it
> worth working round the Numeric array problem or does anyone know if
> things are going to be updated soon? What does Ubuntu Intrepid Ibex
> have? What python-gdal is available for MacOS?
> The workaround involves making sure I pass the right sort of array to
> the writing functions, but that involves knowing what python-gdal
> expects and copying the data when converting it to Numeric array.
> Something worth avoiding. Oh well.
> Sorry this is less of a qgis problem and more of a python-gdal one...
> But I'm sure you guys know the answer...
> Barry
> Qgis-developer mailing list
Arpita
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090110/0c5bcd0e/attachment.html
