[Qgis-developer] Snapping problem
Olivier Tournaire
olitour at gmail.com
Sun Jan 11 07:52:17 EST 2009
Hi all,
I am currently trying to use the snapping capabilities of QGIS, and I face
some problems. When I edit a new geometry, I would like to know the vertices
which have been snapped.
So, I do this as follow, for example with a polyline
void QgsCGALArr2PluginGui::addInArrangement( const QgsPolyline &line )
if ( !m_mapCanvasSnapper )
m_mapCanvasSnapper = new QgsMapCanvasSnapper( m_mapCanvas );
else
m_mapCanvasSnapper->setMapCanvas( m_mapCanvas );
// Differenciation des snaps sur sommets et sur segments
QMultiMap < double, QgsSnappingResult > snappingVerticesResults,
snappingSegmentsResults;
QMultiMap < double, QgsSnappingResult > globalSnappingVerticesResults,
globalSnappingSegmentsResults;
// On commence par checker que des sommets de la polyligne n'existent
pas deja
QString text(""), numericString;
for (int i = 0; i < line.size(); ++i)
QgsPoint pt = line.at(i);
// On teste le snap sur chacun de layers
for (unsigned int j = 0;j<m_mapCanvas->layerCount();++j)
QgsMapLayer *currentLayer = m_mapCanvas->layer(j);
QgsVectorLayer *vector = dynamic_cast<QgsVectorLayer *>(
currentLayer );
if ( vector )
snappingVerticesResults.clear();
snappingSegmentsResults.clear();
vector->snapWithContext( pt , 5. , snappingVerticesResults ,
QgsSnapper::SnapToVertex );
vector->snapWithContext( pt , 5. , snappingSegmentsResults ,
QgsSnapper::SnapToSegment );
// On ajoute les resultats du layer courant aux resultats
globaux
for ( QMultiMap < double, QgsSnappingResult >::iterator
it=snappingVerticesResults.begin();it!=snappingVerticesResults.end();++it)
if ( pt != it.value().snappedVertex )
globalSnappingVerticesResults.insertMulti( it.key()
, it.value() );
it=snappingSegmentsResults.begin();it!=snappingSegmentsResults.end();++it)
globalSnappingSegmentsResults.insertMulti( it.key() ,
it.value() );
it=globalSnappingVerticesResults.begin();it!=globalSnappingVerticesResults.end();++it)
text += numericString.setNum(it.key()) + " " +
it.value().snappedVertex.toString() + "\n";
text += "globalSnappingVerticesResults = " + numericString.setNum(
globalSnappingVerticesResults.size() ) + "\n";
text += "globalSnappingSegmentsResults = " + numericString.setNum(
globalSnappingSegmentsResults.size() ) + "\n";
In my project, all layers are "snappable" to vertices and segemnts, with a
tolerance of 5, and the units are in meter. That is why my toleance in the
snapWithContext is set to 5. The problem is that when I edit the geometry,
the snapping works well (the mouse is attracted when close to a vertex or
segment), but, the above code shows that snappingVerticesResults is empty.
So I do not understand why I cannot retrieve the snapped vertices.
In fact, I simply want to maintain a list of vertices, update it each time a
new geometry is added, but, be aware that if the new geometry has a common
vertex with an already existing geometry, do not add this vertex to the list
of vertices. Could you help ?
Best regards,
Olivier
PS: note that I also tried m_mapCanvasSnapper->snapToCurrentLayer(...) and
m_mapCanvasSnapper->snapToBackgroundLayers(...) without any success.
Dr. Olivier Tournaire
MATIS - Institut Géographique National
73, Ave de Paris
94165 St Mandé cedex, France
tel: (+33) 1 43 98 80 00 - 71 25
fax: (+33) 1 43 98 85 81
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090111/38421767/attachment.html
