[Qgis-developer] segfault
Paolo Cavallini
cavallini at faunalia.it
Fri Jan 16 08:10:33 EST 2009
Peter Ersts ha scritto:
> Borys and Paolo,
> I also just updated QgsRasterLayer::identify() to return a boolean. If
> the provider key is wms then it should do nothing and will return false,
> otherwise it will build the result string(s) and return true. It would
> be good if you could try again with revision 9414 and see if it still
> crashes -- the plugin may indeed still need to be updated.
> There are several other methods that should first check to make sure the
> provider is not wms.
It seems ok now. Anyone can confirm?
All the best.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
